Intermittent jamming DF2000 of MP1600.
  • dawn
    • Mar 2011
    • 48
    Problem: Multiple feeding of DF 2000.
    I have done so far:
    Changed the pick up roller, feed belt, separation roller, torq limiter.
    Cleaned sensors, lubricate gears.
    Any comments would be a great help.
  • fotocom
    • Nov 2008
    • 96
    Re: Intermittent jamming DF2000 of MP1600.
    I have had this problem before. It turned out to be the black plastic pick up roller holder. The holder had worn causing too much play on the belt, which resulted in intermittent jamming. If you remove the metal bar from the pick up roller and pick up roller holder, you should be able to see where the pick up roller holder has become oval.
    • Copierdocisleofman
      Senior Technician
      • Aug 2009
      • 86
      could be a paper feed clutch sticking on and so multi-feeding. I have had this on a similar machine.
      • Vioksrall
        • Sep 2010
        • 84
        kindly check the black plastic guide plate under the ADF near the white metal plate. usually it is broken or disaligned. I usually replaced it with new one. hope this helps.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
          Paul@justmanuals.com
