SC302
  • witech1
    • Jul 2011
    • 7
    [Electrical] SC302
    Hi, I have a Ricoh MP161 with a service code of sc 302. Machine is located in a very humid location, and I run into this problem every summer. I have tried a new HV unit, drum unit, and transfer roller. The only thing I was able to change was the service code. I have temporily put the machine in an air conditioned office over night.
  • JustManuals
    • Jan 2006
    • 9838
    Re: SC302
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      Re: SC302
      302 B
      Charge roller current leak
      The polling module detects a current leak
      of the charge roller.
      • Defective charge roller
      • Defective high voltage supply board
      • Loose connection of the PCU
      You can strip these units down as they are basically a smaller A4/LT sized version of the PCU in the 1018/1027 type machines, You can take the front and rear positioning plates off the pcu and split the drum unit from the dev unit, then you'll be able to see the condition of the charge roller inside the PCU. I daresay though that the humidity is causing the problem as although I haven't had this problem with this particular machine, I've had nightmares with the charge rollers in the MPC3500/4500 in high humidity/damp locations causing copy quality issues.
