feeder b802 ardf jamming
  • lightningjeremy
    • Jul 2009
    • 139
    getting jam codes j056 and j053 on an aficio mp c3500. original feed belt is very worn. gonna replace all original feed rollers. is there anything else i should look out for with these jam codes? thanx
  • tonnerboy
    • May 2011
    • 212
    Re: feeder b802 ardf jamming
    I think you're going the right way.
    • teebee1234
      • Jul 2008
      • 1670
      Besides a clutch, make sure the sensor pits are clean of paper dust. The black flocking will start to get white and throw off the sensors. Dont forget the one from the bottom of the adf at the reg sensor (remove 2 screws).
      • mikadonovan
        • May 2008
        • 2931
        Go ahead and replace the pickup and reverse roller at the same time. Take a look at the torque limiter to check if it has a crack in it. Clean the sensors and pay close attention to the one at the rear when you open the ADF cover. It looks down into a little cupped area that has a tendency to collect paper dust and cause intermittent misfeed indications.
        Teebee, I think you beat my post by a couple of seconds
        NEVER ASSUME ANYTHING
        • teebee1234
          • Jul 2008
          • 1670
          Lol, true.
          • techsass
            • Dec 2010
            • 248
            The separation tire is the main cause of DF jams on pretty much all Ricohs. I carry the Feed belt & Separation tire in my tool bag.
            • lightningjeremy
              • Jul 2009
              • 139
              thanx guys, will be visiting the machine today
