AF3025/3030/3035/3045- scan to folder cannot implement on win7
  • kkwong0209
    • 45
    Hi, I have Af3025/3030/3035/3045 cannot setup SMB scan to folder on win 7, but for win XP no problem. I heard that we have to update the firmware. Is it true? How to update? where can i get the firmware. Thanks
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: AF3025/3030/3035/3045- scan to folder cannot implement on win7
    there are threads here about scan to folder in windows 7 and it helped a lot. try to read it.
    Nobody is perfect..
    • coolbeer
      • Jul 2011
      • 100
      Download latest firmware for scan from Ricoh support, and try typing the path as follows, \\ip address of computer\folder name. This usually works
      • kkwong0209
        • 45
        where can i get the firmware??
        • TonerMunkeh
          Professional Moron
          • 3865
          Off Tessa.
          Hit it.
          • coolbeer
            • Jul 2011
            • 100
            Ricoh-support.com, but you will need engineers log in, account and password.
            • kkwong0209
              • 45
              anyone have free firmware or sell it to me.
              • PinevskiS
                • Jul 2009
                • 283
                Go to "Network and Sharing Center" -> "Change Advanced Sharing Settings" -> Select "Turn off password protected sharing"
                • sk_rj
                  • Nov 2009
                  • 2
                  Hi,
                  Have already tried that also but still no luck.Seems like firmware upgrade is the only way forward
                  thanks
                  • rthonpm
                    • Aug 2007
                    • 2860
                    Firmware
                    Firmware
                    Firmware
                    FIRMWARE!!!!
                    It's the only way to get older models to work. Here's your primer once again:
                    NTLMv2 and SMB2 use a higher encryption method and smaller range of communication methods respectively. Every Ricoh machine from the 3xxx series on (the ones that don't use 'password' as the default for the web interface) are capable of NTLMv2 via firmware upgrades. The xxx1 series boxes all have NTLMv2 natively.
                    For all of you trying to get the older boxes to scan, make a call to your local tech, have the firmware installed and scan away!
                    • keccik
                      i have the firmware u want it???
                      • Llama God
                        • Mar 2009
                        • 1353
                        Check your messages.
