Ricoh 3228c setting switch fax
  • tecnomarco
    • Jul 2011
    • 213
    [Error Code] Ricoh 3228c setting switch fax
    Hello, i have a ricoh aficio 3228c fax board with, i can not set the receipt of transmission can help describing the exact procedure
  • Eric1968
    • 2458
    Re: Ricoh 3228c setting switch fax
    Go to Fax Settings - Key Operator Tools - User Parameter.
    Set switch 3, bit 0 to 1 to enable transmission receipt.
    • tecnomarco
      • Jul 2011
      • 213
      HOW DO I GET IN '"SP"
      • Eric1968
        • 2458
        You don't have to go in SP-mode. You can find these settings in User Tools.
        • tecnomarco
          • Jul 2011
          • 213
          forgive my ignorance but what is in the top left of the keyboard?
          • tecnomarco
            • Jul 2011
            • 213
            User Tools by pressing a dialog "Fax Setup" which unfortunately does not contain the program's print fax report
            • Eric1968
              • 2458
              There's a button with '123' on it. When you press that button and press Fax Setting on the touch panel, you can change all fax settings. You can always download the fax user manual at www.ricoh-support.com.
              • tecnomarco
                • Jul 2011
                • 213
                Thanks Eric68 I managed to solve cordial greetings
