richo 2105 image stretches
  • inkstrum
    • Apr 2011
    • 14
    [Misc] richo 2105 image stretches
    The image blurs in spots and looks like it stretches on some of the impressions on 17" one-sided. On 11" two sided, on the duplex side. Any ideas?
  • teebee1234
    • Jul 2008
    • 1670
    Re: richo 2105 image stretches
    The drum drive pulley on the end of the shaft could be broken, allowing slippage. I've seen the molded recess that traps the pin in the shaft "chipped" out before. When the drum stalls/slips, the image will be stretched as the paper passes until it grabs again. Part #AB030754
