I have a Ricoh Aficio 2022SP that was recently updated with what the web site claims to be the latest firmware for every system in the copier.
Problem is, ever since these multiple firmware updates were installed, the syslog keeps showing lines like this after it reports that ipp was enabled:
#[httpd(90)]11/07/22 05:25:14 Fail in a set of a certificate by FLASH. INFO:
While not an error, a new line that wasn't in the log prior to this problem immediately follows it (it used to say "nrs disabled")
#[httpd(90)]11/07/22 05:25:14 nrs(2) enable. INFO:
Any idea what could be causing this?
One more piece of information.
While I have no idea if this is new or was always like this, going in with telnet shows that the system thinks that there are three network devices.
This may account for it now creating two network routing services (nrs) that it didn't before.
msh> autonet priority
AutoNet interface priority
1: Ethernet(ether)
2: IP over 1394(ip1394)
3: IEEE 802.11b(wlan)
Any help in figuring out what is going on would be greatly appreciated.
Thanks!
1: Ethernet(ether)
Thanks!
