I have a ricoh 3228c automatic setting in receiving the problem is not receive after 2 rings you can help
Ricoh aficio 3228c fax receive automatic
Re: Ricoh aficio 3228c fax receive automatic
Does it send ok? , make sure no one has changed the fax lead as some dont work? next question:does it receive at all?Networking skills are advantageous but use of a 3m vacuum cleaner is essential -
fax transmits it leaves the received transmission, the receiving rings but does not take the line and should not be receiving, attaching another laser fax Brother works in automatic reception work, I also changed the form of the full feature fax ricoh 3228c but not too is receivingComment
