1055 misfed at dupex?
  • loverkoko
    • 35
    hi all i have problem at duplex 1055 when copying 3 paper at dublex mode no problem more than 3 paper duplex misfield at b2 i n normal mode no broblem i change dublex same proplem i put old duplex at anorher machine the duplex working any help please thanks for all
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Re: 1055 misfed at dupex?
    Change all 3 clutches on the duplex unit.
    • loverkoko
      • 35
      i change all dublex and change 3 clauches same proplem the proplem not at dublex the proplem at machine thank u for replieng
      • Eric1968
        • 2458
        What code are you getting in Jam history?
        • loverkoko
          • 35
          no code jaming only
          • Eric1968
            • 2458
            I mean, what jam code is registered in jam history (SP7-507). Then you can see which sensor is registering the jam, and where to look for a solution.
            • loverkoko
              • 35
              jam code 12
              • iMind
                • Mar 2008
                • 1116
                Originally posted by loverkoko
                jam code 12
                so what do you want now, do you want us to read the manual for you, if so, tell us.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Change the registration mylars. They cause odd jamming issues when worn.
                  Hit it.
                  • Fearless V K
                    • 620
                    guaranteed this is caused by the paper feed unit clutches. it has nothing to do with the duplex unit. have seen it hundreds of times
                    Don't take that toner with me!
