Hi, I have a problem with AF1075 duplex, which is paper always jammed at duplex unit. I go to SP7-507 and show code 110, 112, 020 and 008. Anyone please help me. thank you.
AF1075 JAMMING at Duplex unit
Re: AF1075 JAMMING at Duplex unit
First, check if the paper is the right direction in the cassetes.
Second, remove the cover of the ADU and check the clutch.
Greetings... -
You cleaned the rollers in the duplex? Checked for paper fragments in the connector?It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
bad paper feed unit clutches will cause this. seen it many timesDon't take that toner with me!Comment
My bad. you're right. was thinking a generation back. In that case, make sure the paper feed stations have not been contaminated with leaking developer from bad seals on the development unit, and check the gears with one way bearings in the feed stations also.Don't take that toner with me!Comment
Thank guys. I change with new duplex unit, It's work. However, the another machine (using problem duplex) have same problem as before. I cleaned all roller at duplex unit. But still not working...Comment
Try changing the Duplex entrance sensor #AW010058. I had one where the duplex guides were shifting to SEF when I was running LEF paper. Not sure why the sensor effected it, but that's what fixed my problem.Comment
