hello. i already replaced the high voltage (power pack), developing unit, drum unit, harddisk with board and i did memory clear but sc395 still appears. and if i do 5804 developing bias sc395 appears. even 2805, 2801 and 3001 sc395 appears. and if i make just one copy sc395 appears. please help. my machine is ricoh aficio 1035. thank you.
aficio 1035 sc395
Re: aficio 1035 sc395
A lock signal could not be detected within one sec. after the motor start signal was sent, or the LOCK signal was lost during normal operation of the motorSC395 D Drum Motor Error (K)
- Motor harness disconnected or broken
- Obstruction is blocking operation of the drum or motor
- TDCU defective
- Drum motor defective
okay...Comment
