SC672 and "Please wait" remains displayed
  • lupi
    • Aug 2011
    • 102
    [Misc] SC672 and "Please wait" remains displayed
    dear all,
    black & white aficio mp4000 error display sc672 and sc824?
    please...
    thanks and best regards,
  • JustManuals
    • Jan 2006
    • 9838
    Re: SC672 and "Please wait" remains displayed
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • xordi69
      • Jun 2010
      • 200
      repalce hdd, if not controller
      • rsyarcia
        Hair Straightener Tech
        • 711
        If the machine has no options installed then you have to check the controller board.
        Nobody is perfect..
        • TonerMunkeh
          Professional Moron
          • 3865
          x2 on the HDD / controller. These things had a bad habit of blowing controllers when they were new, just like the MP2550/3350.
          Hit it.
          • lupi
            • Aug 2011
            • 102
            all
            thanks,
            I Replace HDD.
            The printer or scanner settings have been cleared
            so they must be set up again.
            regards,
            • lordbison
              • 12
              Hi, good day.
              I have a sc817 on a MP2550. Disconected HD and same code, try to upload new firmware with sd card and no good, the SD card is inserted Pon slot 2 and also try slot 1 and had no response. I turn off the DIP switch 1 on controller board so it boot from the sd card and SC 672 appears......Please, can you help me????
              Thanks!!
              • fbkhan3
                • May 2012
                • 421
                Originally posted by lordbison
                Hi, good day.
                Thanks!!
                Download the firmware,unzip the file,make a folder on sd card and name it (ROMDATA) make another folder in ROMDATA and name it with the machine code just check the machine code if it's D017 or D018,you files path will be looking like ROMDATA/D017or D018 and then firmware files in it,put it in second slot if you have done everything right the machine will boot from card !
                But you need to replace controller beacuse SC817 is related to controller!
                • tazofmiami
                  • Mar 2011
                  • 19
                  I have had luck with disconnecting the HDD then reboot copier go in to sp mode and format HDD #2 "IMH"
                  reconnect HDD and then you should be good. What I like to do is a format all for the HDD. But thats just me. Hope this works for you guys.
