Ricoh Aficio 350 SC-321
  • goldencup
    • Nov 2008
    • 366
    [Error Code] Ricoh Aficio 350 SC-321
    Hi! I would like to ask how do solve the problem SC-321 on Ricoh Aficio 350? I have remove the printer and fax unit, replace ribbon wire and laser unit assembly, replace BICU board,I/O Board, power supply. I have also cleared the memory of the machine and do the 400dpi initial and 600dpi initial. What do you think is the problem? Thank you very much.
  • lupi
    • Aug 2011
    • 102
    Re: Ricoh Aficio 350 SC-321
    Clean the Developer roller bias terminal plate on the Development Unit. The Developer roller bias terminal plate is located at the rear of the Lower Development roller in the Development Unit. The bias terminal plate contacts the Development bias terminal spring at the rear of the mainframe cavity.
    • goldencup
      • Nov 2008
      • 366
      I have already replaced the whole developing unit also the drum unit. still SC 321-00
      • xordi69
        • Jun 2010
        • 200
        it's the day of the door switches and fuser door switches. in this machines must be the first think to do when sc codes of fuser,laser or bias not solved by normal way
        • goldencup
          • Nov 2008
          • 366
          I have already replaced the power supply from a good machine also the the door switches. Still no improvement
          • rsyarcia
            Hair Straightener Tech
            • 711
            1. Originally posted by goldencup
            Same thing I did when I experienced this problem but I still went back to door swtiches issue and was able to solve the problem.
            Nobody is perfect..
            • goldencup
              • Nov 2008
              • 366
              ok i will check and replace the switches 1 more time Thank you for all your help
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment
                from Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads
                Paul@justmanuals.com
                • smac103
                  • Aug 2011
                  • 6
                  have you run LD Beam Position (auto 400 and auto 600)? usually have to run those after replacing laser assy.
                  also, when you say laser assy, if you mean just the laser block, you should also clean all mirrors in the laser assy, especially f-theta lens (first after laser (clean it with a q-tip))
                  also several model of this series had an issue with alignment of the laser assy to the chassis. cant remember which screw, but tuck a flat blade screwdriver under either the left screw or right screw holding the laser assy to the machine and re tighten down the laser assy, rerun beam pitch, and and that should do it. seen that one a bunch.
