sc540
  • Trainee
    • Aug 2025
    [Error Code] sc540
    Hi all,
    I am facing a problem with sc540 in ricoh mpc7501.Someone can help me to solve it.
  • xordi69
    • Jun 2010
    • 200
    • JustManuals
      • Jan 2006
      • 9838
      Re: sc540
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • portviking
        • Sep 2009
        • 18
        Re: sc540
        Originally posted by Trainee
        Hi all,
        what version of the error code are you getting? When you go into the SMC report there are 4 versions dealing with the fusing web for this code.
        • teebee1234
          • Jul 2008
          • 1670
          Re: sc540
          Most likely either the fusing belt is torn or the bearings are shot, locking up the fuser.
          • techsass
            • Dec 2010
            • 248
            Re: sc540
            I've never seen it on an '01 series, but just finished installing a school district with '02s and I've had 5 Sc540s in the past week. It's the new web motor.
            I've been using the charge cleaner motor and splicing the web motor harness onto it. Be sure to turn off Sp2804 or you'll get an Sc305.
            Something else we ran into was jam 23s on almost all of the 9002s, no problems on the 7502s. The duplex switch actuator sticks to the blue rollers shaft. I've been adding a wrap to the actuator spring & bending the bracket up slightly. If you bend it too far, you start getting a jam 16.
            • EOJTech
              • Feb 2015
              • 13
              Re: sc540
              Recently had the same code on a MP5054 with about 325K. PM'ed fuser (sleeve, pressure roller, bearings) and problem solved. No obvious defects with old parts.
