MPC 3000
  • carlosp
    MPC 3000
    Hello, I have an MPC 3000 with a dead control panel and through the WIM i see a 202 code. I have disconnected the laser but to no avail. Any ideas out there?
  • JustManuals
    • Jan 2006
    • 9838
    Re: MPC 3000
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • ragajungle
      Re: MPC 3000
      SC 202 Polygon Motor error - check for pinched wire in laser unit harness behind fax option ( if installed )
      SC 202 Polygon Motor error - replace BICU if CN520 has no trigger on pin 3
      SC 202 Polygon Motor error - replace Polygon Mirror Motor
      • carlosp
        Re: MPC 3000
        bicu and polygon mirror motor fixed my issue as well. replaced as set.
        • mabawser
          Tech
          • Sep 2009
          • 121
          Re: MPC 3000
          had this exact issue last week. dissconnecting the HDD brought the screen back on for me then connected it back up but still got sc202. ordered and went back with a polygon motor which fixed.
          didnt have to fit the BICU, you might want to test this in another machine to check, its an expensive part to fit when not needed.....
          cheers
