How to connect external Key Counter in Ricoh Aficio MPC3500
  • ramdv
    • May 2025
    Can any one help me about the connections & configurations required for External Key counter interface in Ricoh Aficio MPC3500 copier. Where is the location in the Board that i can connect the Harness.
    If you can specify the Key Counter part# , that would be of great help.
    Thanks in advance,
    Ramesh
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: How to connect external Key Counter in Ricoh Aficio MPC3500
    You need the Optional Counter Interface Unit Type A, it installs behind the power supply and connects to the IOB. The cable to the key counter then connects to this board. It doesn't have a part number, it's an EDP code. This is what you will need to connect the key counter, as well as the proper cable from the key counter manufacturer.
    Hit it.
    • ramdv
      Thanks you very much ! for the reply. Can you please clarify my doubts ? As I do not have a service manual, that's the reason iam asking you these questions.
      1) Where is Key counter Bracket Type A located on the board ? Is it comes as default with the printer or i should install it ?
      2) What type of connector (cable) i should use ? Is it 4 pin or something else?
      Please help me !!
      Thanks in advance,
      Ramesh
      • trottinbob
        As TonerMunkeh advised, you need Optional Counter Interface Unit Type A (EDP code 413012) . See instructions for install attached.
        I believe it is for 20 pin connector. The Key counter manufacturer should provide the proper cable for attachment to the Ricoh.
        KeyCounter_A_install.pdf
        • oldschool
          • Mar 2007
          • 245
          Yes it is a 20 pin connector. The TYPE A-EDP kit allows for different pricing based on color vs B/W and paper size. It is also used with Ricoh's print and copy vending. More information HERE. If you need a good vend station than look HERE
          Jamex Tech Support: Saving the world one phone call at a time.
          • tecnicot
            • 12
              Originally posted by tecnicot
              [ATTACH=CONFIG]11310[/ATTACH]
              1) this thread is 10 YEARS old... we consider a thread dead after 2 years of no activity
              2) please translate you post into english .. since the site IS IN english not all of us understand your language
              3) you should start your own new thread since your machine is a CM4000 not a MPC3500
