Aficio 200 IP address problem
  • goldencup
    • Nov 2008
    • 366
    Hi I would llike to ask how do you change IP address of Aficio 200? I connect it via router. Can i access it on web interface? Hope someone can help me. Thank you very much.
  • nmfaxman
    • 1702
    Re: Aficio 200 IP address problem
    Pages 11 thru 15 on the printer option operators manual.
    RTFB
    • goldencup
      • Nov 2008
      • 366
      RTFB
      is there a link or site where i can find TFB
      • teebee1234
        • Jul 2008
        • 1670
        AFAIK these boxes only have a parallel or serial connection, no configuration needed or possible. Most of the ones I remember in the past had a JetDirect box interface for network printing. The external print server itself will have a web interface that you can configure from a pc.
        • goldencup
          • Nov 2008
          • 366
          my unit has NIC card which mean it can be connected to a network, right? I got the ip address of the machine from the printout of the Network Interface Configuration For Ethernet (see attatched file). Is there a way to change the IP address?
          • ccchuah
            • Mar 2009
            • 153
            using the parallel port print server is easy and faster on print job. If you want to change the ip of the machine, using the following command.
            Run the cmd command, on the c prompt, enter arp -s 192.168.1.XXX follow by the 12 digit mac address of the printer
