MPc4501 Photoconductor
  • Llama God
    • Mar 2009
    • 1353
    Hi,
    It's been a while, but I'm after advice.
    Can the MPc2800 type PCUs be modified to be used in the MPc4501 type machines? In addition, I'm assuming that the black PCUs of whichever sort can be modified as per the MPc2800 types to allow black PCUs to be fitted to the colours?
    Any help given as quickly as possibly would be hugely appreciated.
    Thanks,
    Chris
  • Llama God
    • Mar 2009
    • 1353
    Re: MPc4501 Photoconductor
    Ignore this, I know how to do this.
    Oh, you already did.
    Well I'm not sharing, so there.
    • TonerMunkeh
      Professional Moron
      • 3873
      Never tried it sorry Chris, I can have a look at one in the morning tho, I've got an MPC4501 first call.
      Hit it.
      • ptrflrs
        Glorified Parts Swapper
        • Dec 2010
        • 192
        Originally posted by Llama God
        Hi,
        Thanks,
        Chris
        if u r talking about D0292252 pcu then yes u can use in place of color pcu. its a fairly quick 2 minute hack: u will have to cut the other corner off the rj-45 with some wire cutters and extract the small aluminum pin then swap the first 2 wires in the harness. hold the harness with the pin releasing latches facing up and swap the two wires on the left. if u have a small blade u can easily pry them off. i would mark the first wire on the left with a sharpy or make a bend in it so u can be sure to make it end up in the 2nd position -both cables r blue so they r easy to mix up. caveat: after hacking so many i have this down under 2 minutes but my first time took a bit longer. hopefully i was clear enough but if u need help let me know. i think u can $ave around $500 - 600 on all 3 pcus. edit> this is for something else, i hadn't read the whole question but u still might find useful...
        Last edited by ptrflrs; 09-01-2011, 04:20 PM. Reason: duh, didn't read the whole question
        jesus loves you! (everyone else thinks you're an assh*le)
        street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
        Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
        • TonerMunkeh
          Professional Moron
          • 3873
          Unfortunately the PCU's have been changed again. Black is now D089 2250 and colour is D089 2251. Four more to carry!
          Hit it.
          • ptrflrs
            • Dec 2010
            • 192
            oh well, i've been due for a bigger van for a while anyway. maybe i will get that ford transit soon to fit another set of pcus. only have a few mpc4501 out there but they r selling fast... give us a few weeks or months and we will test that hack on these new model pcu's. i haven't had to replace any of those yet.
