Sc221
  • dfs
    • May 2011
    • 25
    [Error Code] Sc221
    Hi All
    Ive been working on an MPC 4500 with error Code SC221, If you power cycle the MFD SC221 Occurs Straight Away, any help would be greatly appreciated. So far ive replaced the following parts.
    Laser Unit Assy
    IPU Board
    BCU Board
    Power Supply Unit
    LD Harness Signal
    LD Harness Data
    Door Switch assy at the front door/duplex door
    When i replaced the LD harness X 2 the MFD is was working ok for around 5 hours then i checked in with the client and Issue re occured Sc221.
    Thankyou
  • Nisspat
    • Aug 2011
    • 16
    Re: Sc221
    I assume you entered all new laser codes in on replacement of the ld unit?
    just a thought
    • dfs
      • May 2011
      • 25
      Re: Sc221
      Yes that was done Cheers.
      • lupi
        • Aug 2011
        • 102
        Re: Sc221
        Originally posted by dfs
        Hi All
        Laser Unit Assy
        IPU Board
        BCU Board
        Power Supply Unit
        LD Harness Signal
        LD Harness Data
        Thankyou
        SC221
        Answer
        Replace the Laser Diode & Laser Sync detect board
        • sam6440
          Re: Sc221
          how to enter new laser code?
          • sakura
            • 132
            Re: Sc221
            SC 221 means Laser synchronizing detection error: start position [K]: LD1
            Cause:
            Disconnected cable from the laser synchronizing detection unit or defective connection
            Defective laser synchronizing detector
            Defective LDB
            Defective IPU
            Resolution:
            1. Check the connectors
            2. Replace the laser-synchronizing detector
            3. Replace the LDB
            4. Replace the IPU
            • sandmanmac
              • 3983
              Re: Sc221
              Seriously? You're gonna replace the LD Unit without a service manual? Someone may come along with the Pages from the manual for you, but I hope not. It's just ridiculous that you wouldn't invest a few bucks in a reference manual for a job like that
              • sam6440
                Re: Sc221
                Thanks all,I already settle that problem ...I just changed the nvm..
