1515mf printer stalls
  • Rick
    • Mar 2007
    • 277
    This machine when printed to by all pcs wont print until they turn off then on . Is this a machine problem or network problem ?
  • totoro
    • 568
    Re: 1515mf printer stalls
    Does it print without an issue if you use a crossover cable direct from a pc bypassing the network?
    Totoro
    • rthonpm
      • Aug 2007
      • 2859
      Does it stall if you try configuring the print port for LPR? I seem to remember having a similar issue a few years ago where changing the port for whatever reason solved the issue. The queue name for Ricoh LPR ports is lp.
      • bryand
        • Jul 2008
        • 92
        I have seen this on many different brands/models recently - if they are using Windows 7 it is a driver port problem. Check the port in the print driver and make sure it is the Ip address of the copier.
        • tonnerboy
          • May 2011
          • 212
          Are you sure that you do not have any IP conflits??
