ricoh aficio 2090
  • antoney suresh das
    • May 2011
    • 103
    ricoh aficio 2090
    hi , yesterday a af 2090 propped up a error msg sc 870 and sc 925 hard disk error in spite of clearing the memory the error still persisted so i decided to remove a set of harddisks from a good working machine to install on the m/c showing error the same error propped up.Now i put back the harddisks from i removed from the good working the m/c which was working well now shows the same error and sort,edit, duplex options are disabled i am in a fix can someone pls help i'm desparate.
    thanks
  • prntrfxr
    • 1622
    Re: ricoh aficio 2090
    Try posting this in the Ricoh section of this site. You might have a faster response.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
