SD cards from Kir-C3
  • limo
    • Jun 2008
    • 103
    This is just a tip.
    When your installing a fax unit on a Kir-C3 which is having the printer/scanner option already installed the SD card for the adressbook is not neccesary to be installed.
    Before this card was only 12mb but now is 122mb and at this size can be used for firmware upgrade.
  • Jomama46
    • 2900
    Re: SD cards from Kir-C3
    I believe the card is for backing up the address book.
    sigpic
    A+; Network +; PDI+
