Savin 2525 Default Scan Settings
  • garf12
    I just got a Savin 2525 yesterday. I am wondering if there is any way to set the scan settings so they default to PDF and 400 dpi resolution. It really sucks having to set those every time I want to scan something. The installer thought that you could but never could find the settings.
    Thanks.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    A Savin C2525?
    Select the scan settings you want as defaults.
    Then on the right hand side of the ops panel there is white button at the top with a diamond shape icon on it '[ ♦ ]'.
    Press that and you should see a touch screen button 'program as default'.
    • garf12
      thanks daz that was super easy. I can't believe that the installer didn't know that.
      • Cipher
        • May 2006
        • 1309
        Out of all fairness it used to be set in a different place on all the older models.
        It caught me out the first time as well.
        • fausto1981
          IT Technician
          • Dec 2007
          • 146
          yeah same here, in the older models it used to be in "Scanner Features"
          but for the resolution you would still have to create a program or just set it as default.
