RICOH 2090
  • antoney suresh das
    • May 2011
    • 103
    RICOH 2090
    Hi.
    I've still have had no luck with my problem SC 870 ,SC 925 the duplex , edit, sort functions are disabled on the display<br>tried all the suggestions nothing seems to work. can some expert help please!
  • JustManuals
    • Jan 2006
    • 9838
    Re: RICOH 2090
    Paul@justmanuals.com
    • rsyarcia
      Hair Straightener Tech
      • 711
      Re: RICOH 2090
      have you formatted the hd or changed it?
      Nobody is perfect..
        • May 2011
        • 103
        Re: RICOH 2090
        Yes i have tried chaging the HDD i have formatted it when i tried to execute stamp data download it the screen returns with failed error 30 am i doing something wrong??
        • rsyarcia
          • 711
          Re: RICOH 2090
          replace the hd with new one
          Nobody is perfect..
            • May 2011
            • 103
            Re: RICOH 2090
            You mean brand new un formatted 40gb hdd?? After that what is the steps i follow to restore the machine.My only objective is to restore the duplex ,edit, and sort functions
            • rsyarcia
              • 711
              Re: RICOH 2090
              USE BRAND NEW HDs.
              NOTE:
              The controller recognizes both disks as one disk unit; therefore, both disks
              must always be replaced together, or there will be errors.
              1. Remove the controller box cover. (
              3.15.1)
              2. HDD bracket [A] (
              ! x 5, # x 4).
              3. Hard disks [B] (
              ! x 8).
              4. If you intend to re-install the same disks in the machine, confirm the correct
              connections before disconnecting. After the disks have been formatted, they
              are not identical, and each disk must be connected to the correct connector.
              NOTE:
              The external terminal connections of HDD_A and HDD_B are,
              respectively, IDE1 and IDE2. In the Point-to-Point diagram, CN135 is
              the connection point for IDE1 and CN136 is the connection point for
              IDE2.
              5. Install the new disks.
              NOTE:
              If the disks are new and unformatted, they are both identical, and can
              be connected in either position.
              6. Turn the main switch on and execute 5832 001 (HDD Formatting . All) to
              format the new disks.
              7. Install the stamp data using SP5853. (
              .Stamp Data Installation., 5. Service
              Tables.)
              B070R160.WMF
              B070R943.WMF
              [A]
              [B
              Nobody is perfect..
              • rsyarcia
                • 711
                Re: RICOH 2090
                Both HDDs must always be replaced together as one set.
                Nobody is perfect..
                  • May 2011
                  • 103
                  I did exactly as you guided me when i download stamp dsta the screen returns with the message error 30 .What could be the possible problem??
                    • May 2011
                    • 103
                    Re: RICOH 2090
                    hi,
                    Can any guide me how to upload to SD card on af 2090??
                    • rsyarcia
                      • 711
                      Re: RICOH 2090
                      error 30 means the machine cant detect the hd, check the connection make sure that you installed the hdd properly,follow the instruction on the manual.
                      Nobody is perfect..
