DSM618 Scanrouteur
  • hmac
    • Aug 2009
    • 129
    DSM618 Scanrouteur
    Hello, I'm looking for a set dsm618 in a scanner.
    Scanrouteur I install, I create destinations, and I add the photocopier in the I / O.
    There is no firewall or antivirus blocking.
    But the list recipient does not update on the copier.
    I note that in FILE TRANSFER, distribution options, the server is 127.0.0.1 but I can not change the ip.
    How?
    _________________
    HMac.
    _________________
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
    Re: DSM618 Scanrouteur
    How?
    Unless you're committed to running Scanrouter Pro, NOT Lite, why on earth would you want to be saddled with this albatross?
    This machine has built in scan to folder and email, so it's nearly impossible to justify the use of Scamrouter, errrr.... Scanrouter.
    • hmac
      • Aug 2009
      • 129
      With the DSM618, you can not use ScanToFolder just ScanToMail,and my client does not wish to use its mail scanner.
      So I use Scanrouteur. But it's how you change the IP address of the server distribution?
      _________________
      HMac.
      _________________
      • chaunce54
        • Sep 2009
        • 32
        You cannot change that setting, it is updated when the device is added in Scanrouter admin tool. Either you didn't add the right photocopier as the I/O device, or there is something going on with your network that the computer and photocopier are not communicating. Are the IP address and gateway settings correct on the photocopier? Are you sure that there is not a firewall (Like windows built in firewall) blocking it?
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          Sorry, my bad.
          The Lanier site said "Scan to Network" - silly of me to think that meant "Scan to Folder".
          Try to see if there is an SP5845-2. This works to change the ScanRouter IP address on other models; I have no idea (or manual) for this one.
          The text below is from the MP3045 manual:
          5845 2* IP Address (Primary) Range: 000.000.000.000 ~ 255.255.255.255
          Use this SP to set the Scan Router Server address. The IP address under the
          transfer tab can be referenced by the initial system setting.
          • nfcopiers
            • Sep 2011
            • 37
            sir i have a problem ,,,,with may ricoh 3010 a dirty copy..but have a new developer,drum,blade..in front of the paper
            thanks hope you can help me/..thanks a lot
