Faxing to Lanier 5645 crashes PC
  • tcapewell
    Hope someone can shed some light?
    We have a Lanier 5645 MFP and when you attempt to send a document for fax via the the print menu it crashes your PC and forces a reboot with no error message.
    On the Lanier log it reports an error in communication.
    This doesn't seem to happen to smaller documents - <100kb or so, which fax ok, but I can't pin it down to an exact size issue or document format.
    Anyone have any ideas or further advice for investigation?
    Many thanks
    tcapewell
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Are you running the latest LAN fax driver?
    v1.50 Has the following changes:
    Supported: Microsoft Windows Vista 32bit
    v1.37 has the following changes
    Fixed: If Microsoft Security patch MS04-011 is applied, errors occur while transmitting data to the printer.
    MS04-011: Security Update for Microsoft Windows
    Fixed: Malformed data was sent to the machine when "pcAnywhere" was running on the computer.
    The surface palette made by the driver has been reversed.
    ROP code of DrvBitBlt has been memorized.
    Wording has been corrected for the Cover Sheet Editor
    Temporary file is created when broadcasting transmission.
    The width of drop down list for the Address Book file name display box has been made adjustable.
    • fausto1981
      IT Technician
      • Dec 2007
      • 145
      Yeah just update the LanFax driver.
      I had the same problem but that was like a year ago bro:
      my dealer was selling Gestetner back then.
      this was released by them check it out
      https://gestetner.custhelp.com/cgi-bin/gestetner.cfg/php/enduser/std_adp.php?p_faqid=63072
      • tcapewell
        Excellent, thanks guys!!!
        Removing the security update solves the problem.
        But as we have Windows updates checked and pushed out automatically, I'm having to go down the driver update route.
        However, when I do this, the driver appears as LanFax M1 (as it was previously) should this be the case? Is there anyway of getting more detailed driver information to check that it's the v1.50?
        • unisys12
          • 489
          If you download the driver from the OEM site, it is the latest and greatest. They do not post older drivers. General rule of thumb, for me, is to never use the CD's whenever possible.
          Ricoh could save themselves quite a lot of cash over the course of a year if they would just stop shipping them with the machines. I did an install on a Savin 4540 a month or so ago and had to use the CD since the customer was starting a new office and had not had their DSL installed yet. Anywho... I figured the Lan Fax driver on the CD was good, since this problem almost a year old, and found out it wasn't. I had to return, download the new driver and uninstall/reinstall on 5 PC's.
          sigpic
          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
          • SGT_Snacks-64
            • Oct 2007
            • 157
            It's the same with anything these days. Graphics cards being the main culprit. I've never used CDs from Graphics cards, I throw them away, and if I sell them on I provide the latest driver on CD.
            Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
            Asus P5E-VM HDMI
            4GB (2x 2GB) Corsair XMS Xpert II RAM
            ATi Radeon 4870 512MB GFX Card
            2x 74GB WD Raptor Sata HDD (RAID 0)
            500GB Seagate Barracuda Sata II HDD
            500GB Hitachi Sata II HDD
            600W500att OCZ PSU
            -TOTAL HDD SPACE 1148GB-
            • tcapewell
              All working now having successfully updated the driver.
              Many thanks to everyone who posted and helped with this!!
              • fausto1981
                IT Technician
                • Dec 2007
                • 145
                You are Welcome tcapewell.
                Check the Attachement. it will show you the steps on checking the version of the driver you have now.
                !!!I have a different Driver it is not the same one mine is V.1.46
                • tcapewell
                  So I thought I had updated the driver, but following the instructions above to get the actual driver details (see attachment) it's showing as v1.46 still and not the v1.50 which I had downloaded and run.
                  All I do know is that the fax seems to be working at the moment (fingers crossed)
