Ricoh 3030 SC901
  • pukiro
    • Feb 2011
    • 59
    [Error Code] Ricoh 3030 SC901
    Hi guys
    i been having this problem on a few Ricoh 3030's, any ideas?
    thank you
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 3030 SC901
    If you're getting this code on a "few" machines, are you tampering with the mechanical counter or zeroing the NVram counter? This is the only thing that can cause this SC.
    3030 SC901.pdf
    Hit it.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • pukiro
        • Feb 2011
        • 59
        [ATTACH]11840[/ATTACH]
        hi
        no i havnt tampered with the mech counter or the NVram. I only bought these machines 4-6months ago, and the meter was low approx. 50k - 80k. It could be that the company i got them from did!?!
        i changed the NVram but no luck, what can i do to fix it?
        • TonerMunkeh
          Professional Moron
          • 3865
          You'll now have to try replacing the mechanical counter. Failing that it's a new BICU board I'm afraid.
          Hit it.
          • nfcopiers
            • Sep 2011
            • 37
            nvram counter problem,,,
            maybe you should buy another ram..thanks
            • meldwo
              • Feb 2012
              • 36
              SC901 Mechanical total count error (Mechanical total counter defective)
              The IO board cannot receive the
              mechanical total count data.
              • ponto700
                • 144
                today i recieve mp2510 with sc901.. try to replace nvram, mechanical counter, bicu board, cntroller and still give same problem.. after change power supply board the problem was fixed.
                  • 37068
                  Every time I have seen SC901 it is because the mechanical counter is not connected or the connector is loose. When the controller tries to send a count pulse to the counter, it senses no current and throws the code. On some machines there is an SP setting to turn off the mechanical counter.
                  • ponto700
                    • 144
                    in my case i check all even if the cables and conectors and all was ok... only problem was the power supply but after change it problem was solved!
