Do you want to scan to mail or use it as a twain scanner? if you want a twain scanner you need the driver for this.If you want scan to mail you need scanrouter.Either way you need to know if you have print/scan module or only print module installed in your Copier
I want to scan as a twain scanner
And I had the driver for this
BuT After I install The Ip For the printer and i had print on it by lan, I want to scan On it> Then I Install But It's not to connect
If the machine will print on the lan, then there is no reason why the twain driver should not see it on the network. Are you sure the machine has the scanner option installed? If you are sure it has scanning capabilities, make sure you have the latest twain driver from Ricoh, and have installed it properly. If for some reason it still does not work, you can always try scan to email, all you need is the IP of the SMTP server, and a valid username/password for the email account.
