2238c set fusing unit error
  • budauroland
    • Jun 2025
    set fusing unit error after reset copier to factory values. Can't change region from factory mode. Help me, please ???
  • xordi69
    • Jun 2010
    • 200
    Re: 2238c set fusing unit error
    how put you factory values?
    • budauroland
      sp 5807 001 is available in 2238c ?
      • xordi69
        • Jun 2010
        • 200
        5 808 001 destination code
        • xordi69
          • Jun 2010
          • 200
          5808 not available
          • jummamaster
            • Mar 2009
            • 99
            can you tell some more detail about the problem?
            Ricoh Error Codes
            Canon Error 5100
            Canon Error B200
            j
            c
            • Eric1968
              • 2458
              Do you have a backup on a SD-Card? If so, you can reload the settings back the wayit was before the memory clear. What's the reason for doing the memory clear? You can really get in trouble without a proper preparation.
              • RICOHTEC
                • 42
                you must login in super admin to have acces SP mode to modifie destination code and set up serial number
                • budauroland
                  2238c copier has fuser from cl7000 printer. must be pins incompatibility.
                  input check 5803 7 is 00101010 when fuser and door is out and 00111110 when fuser and door is closed. Bit 0 - fuser is not set, Bit 4 - fuser has european version. Have someone pins map from 2238c fuser. is different for cl7000 ?
                  • pLatik
                    • 169
