Thought I would try the pros here before I bring out Mr. Wireshark.
Customer demo has LANIER LD435c LAN-Fax M8 driver and is using the "E-mail TX results" / "Notify" checkbox so that the communication result report is emailed to the CSR that needs it.
Scan to email/folder is working fine.
I tested it at my shop and it works perfectly, I run Exchange 2010.
Customer I believe is using a linux box on a Windows AD network and this sounds like a mail server issue.
Error attached
20110922152307796.pdf
Error attached
