ricoh mpc2050
  • tulipano
    • May 2010
    • 124
    ricoh mpc2050
    ho sostiuito una scheda bicu di una ricoh mpc2050, mi da errore sc900-001, mentre con la vecchia scheda originale funziona.perche?e pure entrabe le chede sono buone.
    I replace them a card Bicu a ricoh mpc2050, me error sc900-001, while the old original card funziona.perche? entrabe the chedi and also are good.
  • RICOHTEC
    • 42
    Re: ricoh mpc2050
    SC900DElectrical total counter errorGW The total counter contains data that is not a number.
    • NVRAM incorrect type
    • NVRAM defective or corrupted
    • Unexpected error from external source
    • tonnerboy
      • May 2011
      • 212
      Re: ricoh mpc2050
      Did you also changed the NVram?
      I think you need to change the serial nr. Did you check it?
