sc 390
  • mtekla
    • Aug 2025
    [Error Code] sc 390
    I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed the lower development unit gears (set). Vt is 0.00 even after I add toner manually!I have tried to do developer initailisation annd forced dev churning but no luck at all. Any suggestions will be greatly appreciated guys!
  • sharpmind
    • Sep 2009
    • 478
    Re: sc 390
    390 B TD sensor error
    Symptom
    The TD sensor outputs less than 0.2 V
    or more than 4.0 V 10 times
    consecutively during copying.
    Possible cause
    • RICOHTEC
      • 42
      Re: sc 390
      SC 350, SC 352 or SC 390 codes and/or light copies.
      [Cause]
      Toner not being supplied into developer unit.
      [Action]
      Check operation of the Toner Supply Shutter on the bottom of the OPC unit. This shutter has a small tab on it which when pushed against the developer unit pushes the shutter open.
      If the tab/shutter (item 8) is broken replace with; Shutter, toner supply - Part Number G0652241
      • tcs04
        FORMER Techie
        • 1183
        Re: sc 390
        If VT is 0.00v with a new dev you either have no connection to the TD sensor, have overtoned the dev by NOT covering the toner supply slot during setup, or the sensor is blown. Did you use a vacuum cleaner on the dev unit? If yes, you may have blown the sensor with static.
        You should NEVER add toner to a new dev! (Ricohtec) If you do you will NEVER get a good copy! In fact you MUST make sure NO extra toner gets into the dev unit until TD setup is complete.
        • mtekla
          Re: sc 390
          I initialised developer properly. The sc code started after I had changed the developer unit gears. The copies were very faint so I added toner manually after doing forced toner supply several times without success.
          • tcs04
            FORMER Techie
            • 1183
            Re: sc 390
            Did you check the TD reading before making copies or adding toner? After pouring the dev into the unit, assuming the new dev reached the TD sensor, you should still get a reading from the sensor. If you forced toner into the unit then checked the TD reading, it's possible there is just far too much toner in there after you forced it. This would result in TD at 0v and SC 390. You may have some other fault causing the faint copies like a poor drum earth or dev bias connection... you have refitted the drive dog on the back of the pcu? if not, the drum will drive but the dev unit wll not.
            You must never, NEVER add toner or take a "normal" copy until the TD reading has been checked and I would always run 10 white copies and check VSP / VSG before removing the paper cover from the dev hopper. Once you add toner, if there is a problem, you will probably need another dev.
            • mikadonovan
              • May 2008
              • 2931
              Re: sc 390
              Sounds like you might have a broken auger shaft in the dev unit.
              NEVER ASSUME ANYTHING
              • mikadonovan
                • May 2008
                • 2931
                Re: sc 390
                [Cause]
                [Action]
                That looks like a B079 PCU.
                • sharpmind
                  • Sep 2009
                  • 478
                  Re: sc 390
                  You said that even after replacing new drum set and developer the copies were still faint. It happened to me two days ago when I replaced new drum set but still the copies were too light. I found out the transfer roller was not fixed properly. I would suggest that you remove the transfer roller and clean it. Make sure you clean properly the area where the transfer roller is fixed.
                  • Aneesh
                    Re: sc 390
                    I was facing the same problem and it solve after replac the power supply.. try this atleast..
                    • rsyarcia
                      Hair Straightener Tech
                      • 711
                      Re: sc 390
                      it happened to me with the same model, it was the toner that they used. replaced the toner with genuine, change the developer since it is already spoiled.just an idea.
                      Nobody is perfect..
                      • vitalra
                        • Feb 2017
                        • 16
                        Re: sc 390
                        Hi guys, I too have the same problem with Ricoh Aficio MP2000, after 9 390 error copies Wonder how we measure the TD values (type VT etc.)
