transfer unit sounds loud noises(2035)
  • akbareshghi
    • Sep 2010
    • 261
    [Misc] transfer unit sounds loud noises(2035)
    my transfer belt while copying process is doing , have a loud noise , then i remove transfer unit and manually rotate right gear , i heared the gizh gizh sounds
    please help me about eliminating this sound and if necessary , grease the parts inside the transfer unit
    thanks a lot
    Color printing with lowest cost per page is my love.
  • Eric1968
    • 2458
    Re: transfer unit sounds loud noises(2035)
    Simple, lubricate the bushings and if that doesn't help replace the transfer belt assy.
    • totoro
      • 568
      I never grease anything in the transfer unit. The toner will mix with the grease and give you nothing but problems. Take the unit apart, vacuum it clean, remove the belt and gears and clean all the shafts. You should probably change the belt and cleaning blade while you're at it. Inspect the gears for worn teeth and replace if bad. See if anything binding as you take it apart.
      Totoro
      • akbareshghi
        • Sep 2010
        • 261
        i remove transfer unit and transfer belt , Belf drive gear and opened set screw (2)
        Lay on a flat, clean surface and fold the unit to release the tension on the belt
        and remove Transfer belt after that clean all of parts inside and under the transfer belt specially Driven Roller - Transfer Unit(A232 3885) , Bias Roller(A232 3889) and
        Drive Roller - Transfer Belt(A232 3894) and both Arm - Transfer Belt(black plastic with part number A232 3893)
        and the sound eliminated
        • rthonpm
          • Aug 2007
          • 2859
          Did you try lubing the transfer cleaning blade with toner? The sound could be the cleaning blade sticking to the transfer belt.
          • Cipher
            It's not easy being green
            • May 2006
            • 1309
            There is a small bracket that comes partially unstuck on the inside of the transfer unit causing it to rub and vibrate against the transfer belt.
            (Sounds like a buckling type noise).
            If you take the cleaning blade off it is located near the middle under the plastic lip.
            *It can be hard to spot as it's normally covered in toner.
            **This small bracket is not marked in the parts catalog or the service manual.
            • akbareshghi
              • Sep 2010
              • 261
              please insert one image of it
              thanks a lot
              • Cipher
                • May 2006
                • 1309
                Roughly where the red arrow is (inside the unit).
