mpc 2500 fault finding
+ More Options
Posts
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi guys, on said machine, when in test print mode, how do i print a colour from one drum only. On previous ricohs i could print a test pattern using just one colour, how is it done on this machine, is it select a user colour??
    The reason for this question is that on some of these machines, i get bands down the edge of the copies (normally when the drums are getting worn) and would like to see which drums are causing the fault.
    Even if you select a particular colour to print from, you have to select full colour in copy mode, which then prints from all drums (im sure).#
    Any suggestions??
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • unisys12
    • 489
    Yes, you do this this through User Colors from the copy control panel. I think you reach it through the Edit menu at the bottom on the screen. Then choose User Color, then Custom Color. Place a blank page on the platen, choose black, cyan, magenta or yellow and hit the print key.
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      If you switch on SP5-618 and change data to 0 then this changes display to allow 2 color and single color
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        In the SP modes...5xxx you can select the test pattern desired and specify a single color from cmyk or a composite of rgb. I use this frequently for trouble shooting.
        Mystic Crystal Revelations
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          Thanks guys, much appreciated, i knew it could be done through user colour, but the sp 5618-01 will certainly help, thank you.
