I received the following error codes on a Ricoh Aficio 401: SC324 and SC341. However, I was not able to find these error codes in the service manual. I was wondering what would cause these error codes and if they are even error coded for this machine? If they aren't error coded found on this copier what can be done to fix the problem? The error codes comes up after so many copies have been ran. Any help appreciated, thank you.
Ricoh Aficio 401 Error Codes
