Ricoh 2027 SP Controller firmware "corrupt"??sc 819
  • fshead
    • 2356
    hi
    havent seen this code before but it looks like the controller firmware may be corrupt.
    i have the 1022 firmwares but cant say if i have the 2027.
    are they the same?
    if not does anyone have the latest ver?
    if so id appreciate it as im just in transit from vacation and dont have my work laptop.
    thanks in advance.................
  • zed255
    How'd ya manage that?
    • 1024
    Re: Ricoh 2027 SP Controller firmware "corrupt"??sc 819
    The 1027 and the 2027 are NOT the same. SC819 is a 'watchdog' error, could be corrupt firmware, bad memory DIMM, HDD if one is fitted or the controller itself.
    • mikegs1000
      • 2
      could be board connectors, i have had a few of this series random software errors and have just reseated all the boards
      • gregoriojc
        • Aug 2008
        • 56
        which version of controller firmware you have, so i can send you the right one
        • fshead
          • 2356
          hi
          i just got in from sunny orlando and am gearing up to play catchup on down machines.
          havent been up to the account but i figure i ll do the reseating of connectors,format the hdd
          and ck for staples,sep all xtras ie. adf and sorter.BUT just in case all else fails id like to have some
          firmware to reload.
          thnx,
          • Jomama46
            • 2900
            Open the bypass door and check the metal name tag. The product code will be on there. Either B089 or B027
            sigpic
            A+; Network +; PDI+
            • fshead
              • 2356
              just reseated all the main brd connectors after cleaning and reseating memory and print/scan dimm failed to help.
              thnx
              • Jomama46
                • 2900
                Replace the 128MB Memory DIMM
                sigpic
                A+; Network +; PDI+
                • Cipher
                  It's not easy being green
                  • May 2006
                  • 1309
                  Does the machine work if you power up with HDD unplugged?
                  Assuming it has one fitted.
