RICOH MP C4000 - MP C2800
  • dant
    • 10
    How do you modify a Ricoh black drum 2232244 to be used in place of a color drum?
    Thanks in Advance
  • freddyheady
    Re: RICOH MP C4000 - MP C2800
    you need to file the plug on the rear of the unit, the plug has an angle cut on one side, use a file to shave it down so you have an angle on both sides. if you dont take enough off you will get a pcu unit not set correctly error.
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      That is best case scenario. You can get yourself in a world of shit if that plug is not filed enough.
      Just a warning. Get it right the first time.
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • freddyheady
        I have never found myself in a "world of shit", have done this probably 30+ times
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          Obviously never had the female connector in the rear of the machine get smashed up.
          I've swapped a ton of these units, and yes, it has only happened once, but it happened. Try explaining to a customer that their machine just requires a new drum and they will be up and running in 20 mins, then you smash the connector and have to explain they wont be able to use the machine until you can order the broken bits in.
          What do I care anyway, a warning is just that.
          • Jomama46
            • 2900
            Roger that last transmission! and by "broken bits" he means the whole rear frame! Been there, done that! But on the plus side it gave me a female jack to measure my future mods with.
            sigpic
            A+; Network +; PDI+
            • eddz
              • Oct 2011
              • 9
              I have used a soldering iron for melting the angle and getting that pin out. Cleaned up the edges with my pocket knife and didn't have to disturb the customer with the filing sounds, and I keep the tip cleaned to keep the melting plastic smell to a minimum.
              eddz
              • Mambos78
                • Mar 2011
                • 3
                i do that all the time... no problem!!!
                • nick40
                  • Jan 2011
                  • 47
                  the header say MPC4000 but the part number you are asking is for the previous model. If you meant the MPC4000 the part number is D0292252 and just filing the plug will not do it.
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    Yes indeed, our broken drive assembly stands tall in our workshop hall of SHAME.
                    • eddz
                      • Oct 2011
                      • 9
                      yes after modifying the connector, I push it in gently and if it doesn't latch easy, out it comes for more trimming. I use a flat bladed soldering iron which works well and it was a cheapo. Also carry an EXACTO knife for help in lifting tabs when you have to change the wires on the MPC 2800-3300-4000-5000. I found if I remove the little pin when modifying, you generally are ok.
                      eddz
                      • Jomama46
                        • 2900
                        I mod them all in the shop before they go out and use a moto tool with a cutting wheel.
                        sigpic
                        A+; Network +; PDI+
                        • Max
                          • Oct 2011
                          • 561
                          if it is mpc 2800 ull also need to swap 2 wires in the front of the pcu
                          • techy69
                            here ya go.
