Ricoh Aficio 1027 Drum Unit Reset
  • hknwbec
    • 214
    Could you let me know how to reset the drum replacement on Aficio 1027.thanks
  • Max
    • Oct 2011
    • 555
    • hknwbec
      • 214
      Re: Ricoh Aficio 1027 Drum Unit Reset
      Thanks !
      • salmandol
        • Mar 2009
        • 107
        providing you replace dr and dv run td sensor adjustment
        • Eric1968
          • 2458
          This is NOT a drum reset. Only the 'Replace Photoconductor'-message is not visible anymore.
          • Ollie1981
            Toner Monkey
            • Mar 2008
            • 417
            The "replace photoconductor unit" message is reset when either:-
            1/ If you are using the complete consumable unit (type 1027), when the unit is replaced there is a one shot flag on the rear of the unit that actuates when the unit is inserted for the first time. This makes the machine perform a dev initialisation and resets the alarm.
            2/ If you are rebuilding the units, once the unit is reassembled and back in the machine you manually run dev initialisation and this will reset the message.
            Be warned though if you run dev initialisation without replacing the dev just to get rid of the message, you are setting yourself up for a world of problems shortly down the line.
            • hknwbec
              • 214
              Thanks for your advice
              • flo
                Engineer
                • Mar 2009
                • 44
                i think 2801 (enter) would take all troubles away from you und enjoy the next 60k Copies
