ricoh mpc2050
  • tulipano
    • May 2010
    • 124
    ricoh mpc2050
    I have a prejudice with ricoh mpc2050 scantofoulder configuration, scan to email, faxemail, ecc.li I would like to copy everything before formatting the hard drive and Azerbaijani fax memory. how can I do?
    salve ho una ricoh mpc2050 con configurazione scantofoulder,scanner to email, faxemail ,ecc.li vorrei copiare tutto,prima di formattare hard disk e azerare la memoria fax. come posso fare?
  • Jomama46
    • 2900
    Re: ricoh mpc2050
    I think you will just have to print out the faxes and doc server but you can back up the address book to an sd card as follows:
    DownLoad Prepare a formatted SD card, turn off the machine , install the SD card into the SD card slot 2. Turn on the main power switch, enter SP mode, DO SP5846-051 (Backup all Address Book)
    UpLoad Use SP5846-052 (Restore all Address Book)
    sigpic
    A+; Network +; PDI+
    • tulipano
      • May 2010
      • 124
      Re: ricoh mpc2050
      thanks
