lanier ld020 (copyprinter)
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi guys, i know its the copier forum, but do any of you guys have any experience on the copy printers by ricoh?
    I went to one that was leaving marks on the backside of the copy, the ink seemed to be getting on the reg roller, i cleaned it, then it got dirty again. So i looked round the back, touched a solenoid and it went clunk. from that moment i cant get the drum out!!! and when i look inside, the cloth around the drum is torn!!!, Now it wont work at all!!!!
    Any ideas as its now giving error e -06 (drum movement).
    i knew i should not have touched it lol.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • Reshee
    Did u touch it while the machine running??
    • ejfh1
      • 16
      push down on reg roller, front and back, it should click back in to place and you will be able to rotate drum manually to home position,give reg roller a good clean, customer has most likely been copying on both sides, and the ink has rubbed off on to reg, remove torn master and you should be good to go.
      • mikadonovan
        • May 2008
        • 2931
        Guys, the original post was from 3 years ago. He's probably fixed it by now.
        NEVER ASSUME ANYTHING
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          well, someone else did lol.
