ricoh 2090 hardisk problem
  • henrycool
    • Oct 2011
    • 9
    hi friends
    this is henry and i had 5 ricoh2090 machineds with hadrdisk complaint . i replaced with new hardisks but it wont work.pls let me know the installation procedure and firmware for the same
    thanks in advance
    henry
  • Eric1968
    • 2458
    Re: ricoh 2090 hardisk problem
    What SC-codes did you had? If replacing the HDD's in 5 machines won't work, the HDD isn't causing the problem.
    • henrycool
      • Oct 2011
      • 9
      i am sorry in all the machines the hdd are problem .... duplex sorting functions are not working....pls share how to resolve the problem
      thanks
      henry
      • henrycool
        • Oct 2011
        • 9
        the machine is working properly without duplex and sorting functions..... i replaced with new hardisk also but it wont work
        • henrycool
          • Oct 2011
          • 9
          pls help me to sort out the problem ....... i am in urgent
          thanks
          henry
          • henrycool
            • Oct 2011
            • 9
            i need the sd card and installation files to enable the duplex and sorting functions pls help me
            thanks in advance
            henry
            • xerotec
              • Oct 2009
              • 45
              Re: ricoh 2090 hard disk problem
              tray to format hdd from machine use
              SP 5832-001 HDD Formating ALL then turn OFF then ON
              • henrycool
                • Oct 2011
                • 9
                pls tell me how to get the sd card installation files for solve the sorting and duplexing problem in ricoh 2090
                thnaks in advance
                henry
                • tcs04
                  FORMER Techie
                  • 1183
                  You have FIVE machines with the same problem?!?
                  What happened before the problem?
                  Did you upgrade the firmware on all machines and THEN see the fault?
                  Are you getting something like "Error 32"?
                  Disconnect the LCT and Finisher on one machine, load new system and engine firmware AT THE SAME TIME (select BOTH from the list).
                  Refit the LCT / Finisher. Does that work?
                  • henrycool
                    • Oct 2011
                    • 9
                    i need to ready one machine with sorting and duplex functions pls help me wht to do and the need tools or sdcard files
                    thanks in advance
                    henry
                    • tcs04
                      FORMER Techie
                      • 1183
                      thanks in advance
                      henry
                      I assume you are NOT trained on this machine then?
                      • Eric1968
                        • 2458
                        If you're having HDD-problems then you must have an SC-code or a 'Please Wait' message.
                        • tcs04
                          FORMER Techie
                          • 1183
                          But not on 5 machines unless somebody did something to all of them!
                          • Eric1968
                            • 2458
                            You're right. Maybe he put in the wrong HDD's. There's not enough information to say something reasonable about this.
                            • tcs04
                              FORMER Techie
                              • 1183
                              Odds on it's botched firmware, maybe engine / system installed out of sequence?
