Ricoh 900 developer in a 1105?
  • Travis06
    Tech.
    • 193
    I have a customer that upgraded from a 900 to an 1105 earlier this year. They still have 3 bags of B0709650 developer on hand. Can I use up this developer first or just order B2349650? They are the Toshiba versions
  • tcs04
    FORMER Techie
    • 1183
    Re: Ricoh 900 developer in a 1105?
    Find the serial number plate on the machine. There should be a reference id above the serial number. It should start with B235, B235, B236. If so the dev should be ok.
    • Travis06
      Tech.
      • 193
      Since it is the Toshiba version of the 1105, the reference number is DP-1105. I think I will order the new developer material to be on the safe side
