Are the cl7100 and cl7200 transfer units interchangable?
Transfer units
Re: Transfer units
It looks like the CL7200/7300 transfer unit ' may ' be backwards compatible with CL7100 but not the other way around.
The CL7200/7300 has a additional belt mark H.P sensor, the CL7100 does not (hence it simply wouldn't use it).
The wiring looks identical apart from that.
I've not tried personally though.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - Brother - Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Re: Transfer units
Same issue is discussed in this previous post
http://www.copytechnet.com/forums/ri...fer-belts.html
appear that the belt of the 32 series fit in the 22 series with a little modification in sp modeComment
Re: Transfer units
appear that the belt of the 32 series fit in the 22 series with a little modification in sp modeNEVER ASSUME ANYTHINGComment
Re: Transfer units
I've not tried personally though.NEVER ASSUME ANYTHINGComment
