Ricoh MP161 "Supplies order call failed" message
  • copyaction
    • Oct 2007
    • 985
    Shows alert on the web image monitor page "Supplies order call failed"
    and shows "Failed to connect to server for remote diagnostics" on the copier display
    I was able to hook it up and get it printing and scanning with no problem so I just want to disable those messages.
    thanks
  • tjvincent
    • 280
    Re: Ricoh MP161 "Supplies order call failed" message
    Sounds like the machine was registered to @Remote, or was with a previous customer, you can clear it with SP 5816-209, or if it doesnt have that you can go to memory clear and clear SCS.
    • copyaction
      • Oct 2007
      • 985
      hi, just tried SP 5816-209, and it didn't clear it. This was a lease return so yes it was with a previous customer.
      is this a user setting or can it just be turned off somehow?
      thanks
      • tjvincent
        • 280
        Then you need to go into SPs and clear the setting called "SCS" under memory, which is in SP 5 somewhere.Thats the only other way to clear it.
