Ricoh mpc 2800 load cyan toner cartridge message
  • kiwiyorky
    I have a ricoh mpc2800 showing load cyan toner cartridge message. The toner pump and drum have been replaced but has not cured the issue. Can anyone please advise?
    Many thanks
    Kiwiyorky
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Re: Ricoh mpc 2800 load cyan toner cartridge message
    Try replacing the developer if it's over life. If not, you'll probably need to replace the entire dev unit. Also check out TSB #018 for that model. There are part number changes for the pumps and a flow chart for troubleshooting.
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      If toner is piling up at the dev unit entrance you may have a faulty development clutch. Had this once or twice.
      • rsyarcia
        Hair Straightener Tech
        • 711
        just encountered this also. replaced the dev't clutch problem solved.
        Nobody is perfect..
        • knarfdnul
          • Apr 2011
          • 27
          I assume you have changed the toner bottle as well after having problems with toner pump? Is toner coming down with "forced toner"? - else take off hose on back of toner bottle and vacuum from both ends, I have had a few machines where this happended as well as bad toner pump.
          I hope this helps you.
