Code SC 221
  • Robben11
    • Aug 2025
    [Error Code] Code SC 221
    I have Ricoh Aficio MP 1350 with the code error SC 221 what I can do to this code .
    thanks for help .
    Sami ..
  • jummamaster
    • Mar 2009
    • 99
    Re: Code SC 221
    It is scanner length detection error code.
    Ricoh Error Codes
    Canon Error 5100
    Canon Error B200
    j
    c
    • Robben11
      Re: Code SC 221
      thanks for help but there is no problem in Scanner unit .
      this code make me mad
      • miro
        • Feb 2010
        • 87
        Re: Code SC 221
        You have a problem with laser unit.
        From service manual:
        when a laser diode (other then LDo) fired with the polygon mirror motor rotating at normal speed, an synchronous detection signal was not output within 250 ms.
        solutions:
        -harness connector of the laser synchronization detector board is loose,broken,defective
        -laser synchronization detection board defectiv or installed improperly
        -LD unit defective
        -IPU defective
        -BCU defective
        Call trained tech
