Aficio 1224c poor prints
  • hairybathplug
    • Aug 2025
    Hi all, ive got a 1224c after moving it it has very poor copys, I have changed the PDU and it is still the same. It appers to be starting the print 1inch in and the registration is totally out.prtint error2.jpgprtint error1.jpg It's the same BW as in colour. Cheers Chris
  • xordi69
    • Jun 2010
    • 200
    Re: Aficio 1224c poor prints
    replace lean unit clutch
    • Jomama46
      • 2900
      Or the cleaning unit bracket.
      sigpic
      A+; Network +; PDI+
      • Eric1968
        • 2458
        For 99% sure the bracket.
        • ucinn
          • Jun 2009
          • 383
          Use it as a doorstop and buy a real copier
          • cobiray
            Passing Duplication Xpert
            • Mar 2008
            • 1199
            Don't use it as a door stop, someone is likely to plug it in and use it. I suggest boat anchor or wrecking ball.
            • Ollie1981
              Toner Monkey
              • Mar 2008
              • 417
              Personally I'd be looking in and around the fuser/oil supply for two reasons:-
              The CQ issue in your examples doesn't look like the classic 2-3" smear you get with cleaning clutch failure, also usually b/w or single colour copies aren't affected just full colour.
              The look of the marks has the look of a fusing belt/oil starvation issue to me, did you take the fuser and the oil reservoir out of the machine before you moved it? Even if you didn't did you keep the machine absolutely upright at all times? When you take the rear cover off is everything oily?
              I have had wandering registration/jamming issues to do with oil contamination of the feed clutches when the machine has been tilted whilst moving. Silicon oil basically wrecks everything it comes into contact with apart from the fuser parts it's supposed be lubricating, if it's in the development units, pcu cleaning units, feed clutches or transport brack assy they are basically FUBAR!
              • hairybathplug
                The problem was the upper tension spring on the pdu gearbox had snapped its bracket so the belt was slipping. For a quick repair I drilled a hole in the plastic gear box case, then wrapped wire around the new hole and spring so it had the correct amount of tension. Being a wide format guy and not working on these before I now have two questions is there any timing issses that I need to look at and I have the old PDU that is not cleaning is there any worth in servicing an old PDU and if so any common problems? Cheers Chris
                • mrwho
                  Major Asshole!
                  • 4299
                  Not wanting to derail this thread (not that it didn't happen already), but anyone ever seen one of these making good prints?
                  I don't know but "1224C" and "poor prints" on the same sentence is the perfect oxymoron to me.
                  Mascan42
                  Ibid
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Common problems? The main problem is this model was released in the first place. Get the customer to upgrade to an MPC4501 as soon as possible.
                    Hit it.
                    • Eric1968
                      • 2458
                      I feel sorry for the door...
                      • aabarnes1
                        • Mar 2009
                        • 620
                        Beef does not come from a sheep, colour quality does not come from a 1224, it really is that simple.
                        Grant me the serenity to accept the things I cannot change.
