ScanRouter Lite for Windows Server 2008???
+ More Options
Posts
  • andrewdecruz
    • Jul 2009
    • 74
    Dear All,
    Is there a newer version ScanRouter Lite that can be installed on Window Server 2008? I have a machine model Ricoh Aficio 1045 in a customer place that was using ScanRouter V2 Lite installed on Windows 2003 without any hitch. The problem is after they upgraded to Window Server 2008, i couldn't install using the same ScanRouter Lite version that was used on the older Windows Server 2008. Any help is much appreciated. Thanks in advance.
    Cheers.
  • teebee1234
    • Jul 2008
    • 1670
    Re: ScanRouter Lite for Windows Server 2008???
    It's not supported past XP and Server2003 (some have claimed to make it work but I don't know myself). The best option if the customer is insistent on keeping this device is to cobble together an old PC with XP and install Scanrouter on it, then connect it to the network as a file server.
    • sandmanmac
      • 3990
      When you say you say you couldn't install it. Do you mean you had an error? or it simply doesn't function after install?
      Although it's very antiquated, I've managed to get it to run on all the newer OS's the same as before, the only difference being UAC must be turned off, port 3670 on windows firewall needs to be opened (as usual) and the delivery service must be manually started after system reboot
      • Jomama46
        • 2900
        2 of the 3 versions of Server 2008 are 64 bit. No chance for them.,
        sigpic
        A+; Network +; PDI+
        • sandmanmac
          • 3990
          Actually, no problem there either. I set one up just last week on a client's server 2008 64 bit system
          • Jomama46
            • 2900
            interesting
            sigpic
            A+; Network +; PDI+
