MPC2051 - SC672
  • hmac
    • Aug 2009
    • 129
    MPC2051 - SC672
    Hello,
    Following the printing problem with a client. I change my controllercard photocopier (MPC2051) with that of a photocopier nine(MPC2551), is not quite the same cards. I had the code SC995-03.
    So I put the controller card but the original code SC 672 appears and no way to start the machine.
    The photocopier was working before the exchange of cards, justa few problems printing. But now I can not start it.
    I check all the connections (dismantling and assembly 4 times).
    Have you any idea?
    _________________
    HMac.
    _________________
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: MPC2051 - SC672
    So the original code was SC672- defective controller board.
    SC995-3 -incorrect controller board fitted. (MPC2051 and 2551 are fairly different.)
    Get the correct controller and see how ya go from there.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • hmac
      • Aug 2009
      • 129
      Re: MPC2051 - SC672
      Yes thank you, I find that information about the SC codes.
      But my problem is:
      My copier was working fine, there was just printing problems (butnot from the copier, but the network, information that I learned AFTER the permutation of the cards ).
      So the original card worked very well. I exchange with a card MPC2551, so code SC995-3, normal because it is not the same cards, but when I reinstalled the original card -> SC672!
      And that's where I do not understand!
      I try to change the hard drive, but no results. I will try to change some cables that look slightly damaged, but I doubt it is this.
      Do you have an idea?
      _________________
      HMac.
      _________________
      • PA3040
        • Jun 2014
        • 171
        Re: MPC2051 - SC672
        Hi,
        Did you rectify the this Issue?
        Any observations
        Thanks in advance
        But my problem is:
        • CRISTIAN MULLER
          • Feb 2013
          • 145
          Re: MPC2051 - SC672
          SC 672 could be a lot of things, try to turn the machine on without, HD, fax board, and see if sc ocurrs, then try to plug first HD, and fax board after, had this problem yesterday, was fax board not fit well.
          • PA3040
            • Jun 2014
            • 171
            Re: MPC2051 - SC672
            Dear Thanks for the reply
            We replaced controller board that removed from brand new machine but problem remaining same, then we re fixed the controller board to new machine then the new machine also has same issue ( SC672 )
            • CRISTIAN MULLER
              • Feb 2013
              • 145
              Re: MPC2051 - SC672
              you have tried turn on machine without HD and Fax board?you can enter in service mode?machine freeze at "please wait" screen?I know that service manual says sc 672 is related to communication between controller and operation panel, but for my experience, never was. always this problem is related with HD, RAM memory, fax board or other peripheries.
              PS: You had two machines with same issue now?that su**s.
              • PA3040
                • Jun 2014
                • 171
                Re: MPC2051 - SC672
                Dear CRISTIAN Thanks for the prompt reply
                Yes but same Issue
                you can enter in service mode? Can not
                Machine freeze at "please wait" screen? Yes
                You had two machines with same issue now?that su ? Yes 100% sure
