Hi everyone. I had a call on a MP4000 that is jamming at the registration roll. I think I solved the problem but when I respond to a call like this I allways check the data log to verify the number of jams, paper size, and where it occured. The log said 0 jams. Customer said the jam occured 5 differant times, allways on a recieving fax and allways at the registration roll. Is there a reason it did not log as a jam? Maybe a fax setting? Its a long time customer and I'm sure they know what they are talking about. Appreiciate any suggestions...thank you
MP4000 jamming but not logging in data log
Re: MP4000 jamming but not logging in data log
Actually, it will show the jam but it will be logged as 001 power on jam. I've also had to replace the push switches for the side door and front door switches on some models. Since it's got the finisher/bridge combo you should update the firmware to address the open door timing as well.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
hypertech
